Stock Volt Gauge, Which wire?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PsRumors, Jan 11, 2007.
  1. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    '85 Suburban, stock GAUGES. I pulled the 350 out and put in a 454. I have everything working other than the Volt gauge. It shows 0 volts.
    Where does it get it's reading? The only thing that has changed, other than the engine, is I did a remote solenoid. I did this due to the fact I hate all the wires running down to the starter, along with the fusable links.
    I know I have power and I have done a load test on the battery and at charge the alternator is putting out 14.4 volts.
    I just want the gauge working.
    TIA
  2. dyeager535
    26,975
    Volt gauge reads from the instrument panel printed circuit IIRC. Same voltage that feeds the other gauges. If it's not from the printed circuit itself, it would be from the fuse panel.
    You DID somehow fuse the power leads you changed though, right?
  3. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    I didn't change any power leads. I used the stock leads to activate the aftermarket solenoid.
