Stock volt guage hookup
Discussion in 'The Garage' started by opfor2, Dec 27, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Were is the stock volt meter hooked up on a 90 Blazer? I'm statring to have an issue with the volt meter not indicating correctly so I'ed like to check the wiring but i'm not sure were the wire goes after it leaves the guage cluster.
    Dan..
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Well the wiring diagram I have for your year
    http://brochures.slosh.com
    go to wiring, and 1988-1990, page 2... says the only power-ish thing is the pink and black wire, pins 4 and 17, going to the gauge fuse in the fuseblock. Unless it's the brown wire (#5) off the alternator.
    -- A
  3. dyeager535
    26,978
    The later gauges get their 12V from the same source(s) so things like oil pressure and volt gauges will use the same source. (without looking at the manual)
    I know when I wired mine up with the 1990-91 cluster, that was a major difference between the earlier and later...the printed circuit, and thus the wiring, was much simplified.
    May be the connections for the gauge itself, or if other gauges act up at the same time, probably an instrument panel to cluster connector issue.
  4. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    No one else has any ideas?
  5. dyeager535
    26,978
    You've pulled the cluster?
    If that gauge is the only one that is reading wrong, and you've verified system voltage with a voltmeter, then it's going to be the gauge itself or the connections for it on the cluster housing/PCB.
