Stock wheels for my 35's????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Aug 1, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Stock wheels for my 35\'s????
    I am looking to replace the wheels on my 87k5. I would like to have nice factory wheels. I need 15X10 for the 35" tires, did GM produce a factory 15x10 for any make or model of trucks?
    Rolled
  2. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Re: Stock wheels for my 35\'s????
    Nope, GM never made 15x10" wheels that I know of.Why do you "NEED" 10" rims?Run them 35's on stock 15x8"'s,unless you have 14.50" or wider tires.Mike
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Most all the desert guys run 'em on 8 inchers.
  4. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks for the replies.
    They are 35-12.50-15 and the tire shop recommended 10 and said eights would not work very well. If you say eights then thats what I'll get. In that range I can go with the stock wheel of my choice :-)
    Rolled
  5. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    you could buy some aftermarket steel wheels for very cheap.
    PLus some of the newer wheels as far as i know will have trouble clearing you hubs
  6. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I don't think GM ever made a wheel wider than 8" for a 6 on 5.5 lug pattern.
    You can get some of GM's pro-rally wheels which are 8" wide. If you look around you can find the center caps for them too. Any GM beauty ring will fit the wheel.
    There is nothing wrong with running 12.50s on an 8" wide wheel. I definitely wouldn't run any narrower though.
  7. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    I have a set of General Grabber MT's in a 35 x 12.5" size on stock steel 16.5 x 6.75" rims. Never had a flat with em, have over 30,000 miles on em and they're wearing nice and even...probably 40% left on them. 15 x 8's are definitely not gonna be a problem.
    Rene
  8. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I wonder why the tire shop told me 10s? They were most likely trying to sell me more than I needed. ! I'll pick up some 15X8s out of the paper this weekend and get rid of these rusted american racing wheels asap.
    Thanks for the help guys
  9. BLUESMAN
    Oct 3, 2001
    951
    What kind of wheels are you looking for?I've got almost a dozen stock ralley rims(15x8).And I'm in Phoenix!Cheap!I would go for 8" rims.Mike
  10. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Just in case you can't find any in the paper out there, I've got a set in the "Tires/Wheel For Sale/Wanted" section of this site. You can check it out here , if you would like. I believe they are 8", but I am sure you could ask anybody on this site(well, except for me) to confirm them for you.
  11. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Yep, sounds like they are trying to make a sale. I had 35x12.50's on the factory 15x8 wheels for about a year and never had any problems.
  12. Grim-Reaper
    7,385
    Atlanta
    Well 8's are great off road. it helps hold the bead better. the 10's would be a little better on the street because the tire will tend to roll side to side less. If you like the factory steel look you might check into some Vett reproductions. Simular style. There is a Truck style rally available also but it doesn't have the square slots like the truck rally's have. You can get both in a 10 inch and they will run your trim rings. I think the truck version will even let you retain the caps.
