Stolen Update and fuel filler tube question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Sep 12, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Well I am not sure how many of you remember, But my blazer was stolen then smashed about 4 months ago. I have been going thru a frame off resto. I posted some pics a while back but have been slacking on the scanning lately. Well the good news is she is about there. Lots of little stuff left to do but she runs and drives once again I will get pics up as soon as possible.
    My question is I went to hook up the Fuel filler tube (rubber tube). I am not sure if my gas tank is shifted over or if the tube just shrunk. It just barely reaches, I need it to be an inch longer or so for piece of mind. Any ideas where I can find a longer one? thanks for everyones help...
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    If you removed your tank, then you just haven't raised it enough. Another thing can be that after you removed the body, did you put on a body lift? What about new mounts? These all could contribute to the problem. Lastly, if you need a longer fuel line, you can get one at just about any parts store. you just need to know the size. The kicker is, its about 1$ for each inch you purchase. That sucks.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Its not that easy to find. At least in Kansas. When I had to replace mine, no parts store in town had the size hose I needed. And the GM dealer said that part had been discontinued. I had to go to some industrial rubber supply place to find the right diameter.
    '73 K5
    Chevy good...Ford bad
  4. BlazerBoy
    639
    Chicago IL.
    I havent changed anything it is the same set up I had before.. I am not sure if the hose shrunk or what. But 73 K5 is right I have been trying to find one. None of our parts stores have them. I will have to try and find one from somewhere else, I just dont know if it will be able to handle the fuel with out deteriorating the hose... thanks
    BlazerBoy
  5. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    NAPA carries them.
  6. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    if all else fails take the tube down to Caterpillar, or John Deer, or some other heavy equipment outfit and see if they can outfit you with the size you need.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  7. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Plan B- You can cut the old hose into two pieces and use a short bit of pipe or exhaust adapter and 2 hose clamps in the middle to make it longer. Thats whats usually done for body lifts to make up the diff in length.
