STOMPER is dead.......
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Greg72, Mar 12, 2005.
  1. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    STOMPER is dead.......*UPDATE 3/14*
    Started the truck last night to go out. Let it run for a few minutes to warm up....put on the wipers to clear the ice and snow from the windshield.....then put on the headlights. Pulled the gear selector into Drive and went forward about 3 feet......then
    ...DEAD!
    The engine died...ALL the electrical died...no cranking, no lights, nothing.
    Nothing obvious with the fuseblock (though it has to be a problem elsewhere since EVERYTHING blew) the battery cables looked OK, but I was not dressed for messing around under the hood. I'm thinking some sort of fuseable link, but it's been a long time since I even looked at where those were......
    This is the first time my truck has "let me down" completely. I feel betrayed... :(
    UPDATE:
    Well for those of you who guessed it was the "fusable link" you each get a gold star for knowing the correct answer!!
    I took a quick look today at the fusable link that is somewhat near the battery side in the factory loom. Sure enough, there was a ton of corrosion right at the junction where the wire enters the molded part of the fuseable link. I gave it a slight tug and it came apart in two pieces! :blush:
    .....yet another reason to run with inner fender wells, I suppose....my tires have been hurling snow, ice, salt and slush on that connector all winter. I stripped the wire back and "goobered" it together just to test it and sure enough the wipers started working again, and I was able to start the engine just like normal! :thumb:
    I did a quick "Google" and found fuseable links (14GA even!) at PartsExpress....so I guess I'll order one up and do the repair the "right way".....
    A special thanks to all of you who offered to take Stomper off my hands, or to take at least be involved in the feeding frenzy if I parted it out.....It's nice to know I have SO many friends.... :rolleyes: :D
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    You should let me discipline it for a while. I'll teach it not to be bad anymore ;)
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I think.........bad ground/hot cable connection or like ya said fusible link.
  4. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I was thinking about throwing some dumbbells at it..... :laugh:
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    How about a jump start. Jump on the hood till it starts!!!
  6. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Guess it's done with winter. :(
    You've got either a short or a break.
    I guess even blazers have sick days. ;)
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    fusable link that comes off the battery. The positive battery cable has that one pigtail and it might be crimped to that, otherwise off the junction block on the fender.. it goes from there through the fusable link to the firewall connector then to the fusebox and a fuse could be blown. trace voltage down the line.
    My buddys camaro did the same thing you're describing, i tracked it down in about an hour with a voltmeter and saved the day. :crazy:
  8. mudslinger97116
    mudslinger97116 1/2 ton status
    Mar 13, 2003
    315
    F.G.OREGON
    does this mean it's time to part it out?:grin: :waytogo:
  9. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    So do I go buy a "fusable link" or is the moment where I now replace that molded part with some sort of more modern waterproof fuse and holder (car stereo type deal)???
    Any idea what the amperage rating is on the fusable link? I'm going to go locate a schematic in a couple minutes here and see if it's documented on the factory drawings....
    Tomorrow is supposed to be 37 degrees, so if I can shovel the 12" of snow away from the truck, I'll at least have some warm weather to start tracing the break... ;)
  10. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Greg.If the fusable link has blown there will be some signs.Might have some traces of smoke on the fender or hood,obvious burnt look to the link itself or if none of those are present see if the link is kinda rubbery and will streach.If it does streach the wire inside has blown.
    I believe the rating on the factoy fusable link is 14g.
    If the power dist. terminal looks o.k.(not melted ot burnt looking) I wouldn't replace it.
    You can always jump that fusable link temp. with a 10g wire just to see if that's your problem or not.
    If the link has blown,you then have to figure out WHY?
  11. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Its been too long since i've owned a 1st Gen truck but on the 2nd Gen trucks the fusible link wire comes off the positive starter lug of the starter solenoid and goes to the ignition switch. If the fusible link wire melts you will have NO electrical anywhere. :thumb:
  12. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Hey Dude...
    Sorry I lost you the other night....not much cell phone coverage in the Boston subway system apparently....!!!!
    I'm sick of all these problems. I'm getting a F*rd! :D
  13. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Forget about a Ford, just move back the the left coast where there aren't subways to interfere with cell service and the weather isn't cold enough to give you truck problems and you can actually work on them year round. [​IMG]
  14. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    .....maybe if you west coast guys would stop flipping me off, I'd consider it.
    Buncha meanies. :(
  15. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I will come get stomper out of your hair and make room for your ford. If you want. Free of charge.:D :p:
  16. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    You must resist the dark side!
    Could it maybe be the neutral safety switch?
  17. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    See update at top.... :cool1:
  18. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Freinds...I wouldn't go that far:screwy::wink1:
    Glad it was a easy fix.
    They don't have 14g fusable links on the shelf there?
  19. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Didn't even think that someone local might have them.... I guess it's worth asking, I figured it was too obscure of an item. :confused:
  20. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Na, you should be able to pick up a generic fusable link at any "good" parts store.
