Stoooopid Q about the Ford shock tower gig
Discussion in 'The Garage' started by dremu, Nov 6, 2005.
  1. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    going 52" up front with crossover, so new shocking is in order.
    Okay, so I use the Frdd towers on the frame ... but what do I use on the axle? The original factory mounts, or something new fro the bottom of the shock?
    -- A
  2. d'cheat
    d'cheat Registered Member
    Aug 6, 2005
    19
    Reno, Nevada
    I have that set up. If you use the stock axle shock mounts * as I did* then the ford mounts will have to be cut to make for proper shock travel. I ended up cutting 4" off the ford mounts. Basicly the entire angled section of the tower. Drill new holes on the tower and mount on the frame by drilling *and tapping, if a boxed front frame section* new holes.
    With this setup, you can run the ultra long rancho shocks. :)
    You will also have to cut about 2" off of the stock, axle mount upper plate.
    If you dont have the time to weld up a custom mount, this is the way to go :)
  3. dremu
    Feb 27, 2000
    15,967
    459
    Oh, I've got more time than money right now ... got any pix of what you did, as I'm not visualizing what you mean by chopping up the stock axle mount?
    -- A
  4. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Which Ford ones are you going with? I went with the cast newer style but still have a set of the older ones that most folks use. In fact, I think I already angle cut them too.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My lower shock mounts to eliminate binding, which was really bad on mine when flexed.
  6. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Nice broken sub shaft!!! :doah:
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That took out the stub and the inner. Got bound up in front drive, stretched an ear, out popped the a cap, and the rest is history...
