stoopid atlas question...
Discussion in 'The Garage' started by 84gmcjimmy, Sep 29, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I was just wondering if an atlas was like a custom transfercase, simular to a 205. And would someone just use that for low gearing, or would they also add a klune-v or doubler or something... I dont really get it /forums/images/graemlins/dunno.gif
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I think an Atlas case is just a high end case thats pretty damn strong and comes in pretty much as low of gears as you want. Its for the hard core crew I'd say.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    This isn't the first time this has been explained to you is it? An Atlas is an Aluminum transfer case. Stronger housing than any factory aluminum case in a light duty truck. Chain drive but much stronger than a 241 or 208 chain. They come in 3.0, 3.8, 4.3, and 5.0 gear ratios. Those are the only options on gear ratio. You can just use them as your reduction or you can put a klune in front of them but that is only if you really want to go low.
  4. RustBuket
    Feb 21, 2003
    1,618
    Apparently you know what you're talkin about alot more than I do!!! /forums/images/graemlins/rotfl.gif
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm a hardcore web wheeler what do you expect? /forums/images/graemlins/rotfl.gif
  6. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Ah! but you need to web wheel some more. /forums/images/graemlins/whistling.gif
    The Atlas is NOT a chain drive unit. They are an all gear driven unit like a 205. The rest is correct.
    There is some debate about the strength of the Atlas in a full size running big tires etc. They may not hold up?? Strong emphasis on MAY.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    doh, I was remembering a comparison of a 241 and something elses gear/chain no idea what unit that was.
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That was the first time I ever typed atlas (meaning the transfercase, not book) so I dont know squat about them. Thanks for explaining it to me guys /forums/images/graemlins/peace.gif
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, what they said... mad low gears (up to 5:1), gear driven, strong AL case and big high-spline yokes are available. People who don't want the drivetrain length or weight of a doubler but do want looow gears really like em.
    j
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thus why I want one. Planned about 100" wheelbase and light weight rig next so just what I need.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I suspect they aren't going to last for bigger trucks like ours with 4O+" meats, just for those light 3000 LBS buggies?
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    does anybody knoe anyone whoe is rinning one in a full size, i know they blew one up in the ultimate Avalanche but that was due to some other things, they look pretty bomb proof to me /forums/images/graemlins/dunno.gif still kind leaning toward the dubbler
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    DBlazer and Nonesuch both run them with great success
  14. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I ran one for two years in my old ride. It then resided in a Campbell Ent. comp buggy, and it is now in a TJ thats is gutted with a hawt small block, 60's, 700r4, and comp 37's M/T's.
    My old rig was a K5 w/ 42's, hummer beadlocks, 350, 700r4, and 60's. I beat the piss out of it and never had a moments problem. As long as you get 32 spline front and rear outputs, you are money. I broke numerous 35 spline axle shafts, knuckles, hubs, lockers, etc., but never had a problem with the Atlas.
    I put a strong emphasis on the fact you will not ever have a problem with one of these cases. That being said, anything can be broken under the right circumstances, or with lack of maintenance.
    You can also get an atlas without a speedo housing to make it super short. /forums/images/graemlins/thumb.gif
  15. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    a buddy of mine is building a cruiser buggy with a 465 to 203(rangebox) to and atlas /forums/images/graemlins/eek.gif why i don't know /forums/images/graemlins/screwy.gif
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    like you need one of those anyway
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    DBlazer has a Klune V in front of his Atlas.
  18. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Yah, I run the Klune in front of the Atlass, and some will argue about my /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif!!!!
    I have said it quite a few times before, my Atlass has been a champ. I have not broken anything in it at all so far. I did break the output shaft frome the Klune into the Atlass. I have been VERY happy with mine. It is a set up that I have no regrets at all setting up. I crawl everything. I very rarely bump hard. It has given me the ability to pick the wackiest lines and run places most won't go!!. Again, we like the gnarly-that ain a trail- you are going where?? kind of lines and trails!!
  19. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    if the atlas can handle that, its fine in a fullsize.
    j
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    It has given me the ability to pick the wackiest lines and run places most won't go!!. Again, we like the gnarly-that ain a trail- you are going where?? kind of lines and trails!![/b}
    this being my goal /forums/images/graemlins/wink.gif
