Stoopid Steering Stabilizer Question
Discussion in 'The Garage' started by skink4president, Nov 5, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    Swaping out my steering stabilizer in my '73 K5 with a TC replacement. Nothing fancy just one stabilizer shock replacing the stock one. Actually I'm not sure it WAS the stock one cause it was mounted ON TOP of the axel perch (I think that's what you call it). The suspension is OEM and the top pf the stabilizer tube actually touched the DS leaf spring!?! THAT and it was a b*tch to remove. I was in the middle of putting the new one in the same way when it occured to me to simply mount it BELOW the perch. Which way is correct??? Can't find any good pics in my manuals.
    Thanks for any help on this one.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    thats not a factory setup to my knowledge. Factory has a bracket welded to the driver side axle tube and goes to the hole in the tierod.
  3. skink4president
    Mar 5, 2005
    79
    orlando
    Yeah, that's what mine looks like. Sorry for the crappy description :D. SO does it attach to the top or bottom of the bracket welded to the driver side axle tube :confused:
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    top, if it is hitting the spring I'd look at your ride height and try to figure out if your springs are worn out. THey should have negative arch, but so much as to hit the stabilizer just doesn't sound right.
