Stop Smoking!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Jul 2, 2003.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    I tried to start the Blazer at the boat launch yesterday when it suddenly started to sputter and blow black smoke out the exhaust! After trying 4-5 times I finally held the pedal all the way down and it just barely fired up. Of course it sounded like it was running on 6 cylinders and backfiring severely. After warming it up to normal operating temperature and revving it up to try and clean the out the plugs the problem continued. I only lived 10 minutes away and the wife was running late for work so I took a chance and pulled my 18' boat home. On a small incline before reaching my house I could hear a very loud rattling sound. Like a pinging/detonating sound but much louder. In my driveway I turned off the engine and it had the same problem, sputtering w/ blk smoke. I recently changed the plugs and wires. BTW, it's a '88K5 with a FI 350. Any suggestions? Could it possibly be bad gas or a gas filter? I'm gonna pop the distributor when I get home from work today...
    Before yesterday I never experienced anything like this... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Sounds like it's running real rich for some reason. When you put the boat in/out, how far down did you back in? Any chance the O2 sensor got submerged?
    I believe a clogged EGR could also cause your issue.
    Do you have a TBI scan tool? If not, I would suggest you get WINALDL and check for codes and/or sensor readings.
    Thomas.
  3. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    I don't think the O2 sensor got wet, only the back tires were in the water and it sits on 35's. How much does a TBI scan tool run?
  4. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Do you have a laptop? If so, click the link in my previous post and you can download scanning software for free. If not, you could always borrow one from someone or build a really long cable to go from your garage/driveway to your computer in the house.
    The cable to interface the laptop's serial port to the TBI's ALDL connector can be built with $10 of Radio Shack parts. The instructions for building the cable are located on that website.
    Thomas.
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I downloaded it, but good grief that cable schematic is a foreign language to me.
    Looking at those tables and graphs would probably require some explaining too.
    I am interesting in learning how to use this however. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif
  6. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Do you know anyone who can soldier? It's a real easy cable to make once you get the parts. Print the schematic out and bring it to Radio Shack when you go buy the parts; they could explain it to you.
    As far as the graphs and such, you just have to know what you're looking at. Last time I used it (a year or so ago), it would give me the O2 readings (lean/rich), Throttle position sensor reading, BLM readings (how much the computer has to compensate to make things like mixture, timing, etc ... where they should be), it'll even give you a knock count (detonation/pinging) with respect to throttle position and RPM.
    If you check out ThirdGen.org's message boards, you can find a lot of good info about the program. Last time I was there, there was someone who would even make you a cable for a price.
    Thomas.
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Maybe you got water in your fuel. When did you last buy gas? I would pull off the fuel filter and pour it into a glass bowl and see if there is water in it.
  8. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Good advice... I haven't put gas in it for over 6 months since I had it stored in the garage. I'll pull the filter off tomorrow and see if there's water in it. Stupid question - is it easy to see water mixed with gas??? I'm assuming it's pretty easy to see a seperation line between the two. I usually put HEAT in my vehicles - anything bad about using this product??
  9. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Source for custom made cable Here /forums/images/graemlins/thumb.gif
    Think he charges around $37.00. /forums/images/graemlins/eek.gif
    Byron
  10. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Ed,
    Same thing happened to me, only not in a boat launch. Rent the scan tool, and check the engine temp, I bet it's the coolant temp sensor. When the sensor trips out, the engine thinks it's -3 degrees out no matter what the engine temp. This will make the truck run like a carburated engine with the choke stuck on. The sensor is in the intake with a 2 prong plug in it. If the scan tool tells you the temp is not what it really is, replace the sensor and a new set of plugs should get you runnin like a top in no time!.
    Hope this helps.
    Jeremy
