Stop!
Discussion in 'The Garage' started by cybrfire, Dec 13, 2005.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Not your everday caliper mount and in most cases would cause extremely early rear lock up!.
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    :pimp::pimp: I see you found some time:bow:
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    whats the whole scoop Kert? how ya gonna make that work?
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    more info please
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Holy schnikes!!! Nice.
    How about doing something like that for a front D60 that allows use of a 15" wheel with the 1 ton stopping power (or better).....?
  6. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    one for stopping and one for parking brake?
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Little here and a little there!
  8. Stomper
    May 11, 2002
    3,767
    Iowa
    I believe they ar both for stopping
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    One thing I can say is its an interesting mix of parts to make it all work out, that is to say if it works out since technically nothing has been real world tested.
    More info to come!
  10. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Cool setup, do you mind if I ask some questions or will it blow the secrets?
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    ask away!
  12. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I've read somewhere that it's bad to have two independent pads working on one rotor. Any thoughts? Looks very nice BTW.
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Don't you think it would be far better to design a system that uses an aftermarket dual or quad piston caliper vs 2 Chevy single piston units? I mean granted I guess the cost is probably cheaper. But how do you bleed the second caliper? I mean one will have to have the bleeder pointing the wrong way... unless you use a right and left... doh...
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    It was suggested in another post that you were using a very narrow rear axle so that you could fit duals on it without the typical "bubblebutted" dually fenders. True?
    If so, I take it you're using this setup to go to discs and have a boatload of clamping power?
    I also saw that you were looking for 16.5" dually rims...and those look like 1/2 ton calipers, couldn't you fit a 1-ton caliper on there if you're really looking to stop the SOB or would that just be gross overkill and too much work because of the different mounts?
    Sorry for all the questions, just love your fab work and naturally curious. It looks :pimp: by the way.
  15. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    what about making one for the front?
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Most of the GM front knuckles have clearances built into them for the caliper. You'd have to make a custom knuckle to match I'd think.
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    As far as better or worse its hard to say, a good part of this has been driven by readily available parts. Yep, a left and a right on thea same side takes care of the bleeding issues.
    As far as two independent calipers on the same rotoro being bad, it's been done in other applications and I can't see any reason it won't work here as well. On the other hand there could be a scenario when one caliper would "hang up" and may cause some problems. That has been considered but since this is a prototype, I'll cross that bridge when it falls down!:doah:
  18. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Actually using a standard width SRW axle for the dually which, if research serves, is a few inches narrow WMS to WMS than the DRW. It will save a few inches but not enough to negate the need for Dually bubble but fenders, I love big butts and I cannot lie!
    They will both be used for stopping and will provide for alot of friction surface. Actually though, "clamping force" can be less with more surface area.
    Yes, I am using 16.5 dually wheels. Thanks to Eric M. they should be on thier way shortly. The standard disc conversion that has become so popular just won't clear the rims. This uses a different rotor as well to help with that scenario along with these calipers. Not 1/2 ton chevy, something else.
  19. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Doh, thought I read somewhere you were using a C&C axle.
    Sorry, didn't actually mean "clamping power" per se, just braking force.
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Like Sled dog said, doing much with the front brakes is difficult due to the knuckle clearance. I would like to do something for the front in the future though. As of yet haven't even looked at them.
