stopin distance for 79 blazer
Discussion in 'The Garage' started by rerun93, Feb 7, 2005.
  1. rerun93
    rerun93 Registered Member
    Dec 3, 2004
    98
    chico, ca
    i just wanted to know if this seems normal. when stopin my 79 it seems like i have to put Alot of muscle on the pedal to stop me. now is this because iam so heavy? iam used to little trucks and cars that stop real fast.
    ty for your help
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    heavy, drums in the rear, your still 1/2 ton right? smaller brakes in the front, and for the most part unmodified chevy truck brakes arent the best, dosent help any when you put larger than stock tires on it to.HTH
  3. bigbrownjimmy75
    bigbrownjimmy75 Newbie
    Jan 28, 2005
    salisbury nc
    ive got a 75 gmc jimmy and have the exact same problem, ive got brand new brakes an its still a pain to stop, specially when muddy:grin:
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Had this problem on my 88 until i did a fluid change and got all the air out of the lines. Stopped good after that.
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    How tall are the tires you're running?
    Eric M.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You probably need a new brake booster.
  7. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    check the master cylinder vacuum for leaks.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I second that assumption , hard to brake is usually not in the lines , in the lines is soft or spongy :k5: :k5:
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Oh yeah.... i was wrong it soft not hard. Could be a vacuum line but either way it has to do with the booster.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ok , soft could be either . Start by bleeding them first , its free . Then check everything else . Look for signs of leakage etc . Older trucks should have the brakes replaced anyway seeing as to how old they are . I have done everything but the hardlines since I have owned mine , highly reccomended to repalce it all as you can afford it :k5: :k5:
  11. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I didn't read the first post all the way... I thought he meant it was hard to stop because the pedal was soft.
  12. rerun93
    Dec 3, 2004
    98
    chico, ca
    i will try and bleed them first. i figure it has to do alot with tire size and just being older. just sucks i wonder if there is a swap to do to put a newer style booster and master cyclinder on. cause i know the new trucks stop alot easier then standing onthe brakes lol. ow well if the bleed dont help i will probably swap out boosters.
    also yeah iam still running stock suspension with 4 lift 33 tires
