storing a 350
Discussion in 'The Garage' started by adamforsythe, Nov 18, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    How should I store a 350? Should I crank it over by hand once a month? Leave it? Thanks for any and all help.
    LAter
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    If its running now, warm it up completely, change the oil. Restart and use some seafoam in it(read directions for use) Keep it in a stable environment, out of heat and freeze cycles that create condensation.
  3. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    I Just Covered Mine So I Should Drain It?? Or Leave The Oil In??
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    leave the oil in it. maybe even add a few extra quarts.
  5. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    I don't think it's a good idea to leave oil in it . The oil will give off acid over time, thats the reason they recommend you change your oil every six months or every 3000 miles. Try to get all the coolant out too.
  6. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    you can "store" it in my blazer for as long as you would like
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    but if you're not running the engine, acidity will not be an issue.
  8. 76zimmer
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    Are we talking over winter storage here, or year + storage? I think you should leave oil in it, but only the amount specified. By using the Seafoam, (or trans fluid, or motor oil, whatever) that leaves an oil coating on the whole intake tract, and combustion chamber, and thats also why you should store it with fresh oil in it. Just before storage warm it up good to get rid of all the pollutants in the engine, then drain the oil and refill with fresh oil. Don't give the engine a chance to get cold again. Start it up with the fresh oil in it, and stall the engine out with the seafoam. If you can keep it out of the weather changes, and humidity that is so common east of the Mississippi, this should minimize the condesation that will build up. Ever see your concrete floor sweat on a warm spring day? That happens because its exposed to humid warm air. Keep you garage door closed, and it minimizes that condensation. This should get through a year or so of storage.
