Storing axles
Discussion in 'The Garage' started by mrk5, Oct 26, 2005.
  1. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Well I found a D44 with 4.56 gears to match the 4.56 I had installed in the 12bolt.
    Actually got a D44/14bolt combo, both with 4.56 gears $250.
    I want to store the 14bolt to keep as a backup if something happens to the 12bolt. What would be the best method?
    My thought was to stow it horizontally up off the ground, and completely fill the diff with gear lube. Probably change the lube yearly, unless I break the 12bolt in less than a year.
    My two primary questions:
    Should I fill it completely with lube?
    Should I store the pinion up, down, or the position it would be in the truck?
    Any thoughts?
    TIA
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I don't have any experience doing this but I would say on a set of jackstands, pinion down, filled with gear oil. That way all the bearings are kept submerged.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I think filling it with lube is a good move but store it in a possition where if it gets condensation in it, it'll sit harmlessly at the bottom of the case away from gears/bearings.
    I think you'll need to change the seal if you store it for years as most seals seem to 'stick' to their bearing surface and then tear tiny bits of lip off when you move it.
    14 blt eh? mmmm...nice! :D Me want one too!!!
  4. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Sorry I don't know if you could talk me into shipping you one of those. :eek1: :rotfl:
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Shoulda thrown one into the back of your Dodge when you were in NJ :p:
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Fill it with Redline , turn it real good , drain it , and store the axle covered .
    I say this because the other 12 bolt I have has been sitting with the cover off for almost a year in my garage , and theres still Redline clinging to the surfaces . Chits that good :D
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It was full!!!! I bought so much stuff!!
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Oh go on. Bit of brown paper and string! No problem!
  9. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I was going to rig something up on the yoke, air ratchet or hammer wrench, to give a good spin.
    You've convinced me to run Redline in the 12bolt, but I don't know if I could use for something like axle storage.$$$$ I may just use a BG additive.
  10. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Hmm... Didn't 'something' just happen to the 12-bolt?
    BTW, CD is in the mail. If you happen to meet Toby, I need his address if he wants a CD as well.
  11. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I tell you what, meet me on the western end of Nebraska, and I'll store it under my K5 for you. How's that sound? :deal: :haha: :haha:
    Rick
