storing diesel
Discussion in '1982-Present GM Diesel' started by Heavymetal, Jan 1, 2002.
  1. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    It is my understanding that if you store gasoline for extended periods of time that you must add octane or something of that nature to the gasoline to keep it useable. Is this true for diesel fuel as well? If so does anyone know how long you can store diesel before it goes bad or becomes unusable?
    Thanks,
    Mike.
    77'/87' 3/4 ton Burb, 400cu, sm465, np205, 14boltff, dana44, 4.10s, 35in BFG's.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Yes, diesel will go bad just like gas but maybe not as fast. You can smell the "varnish" in old diesel. 'Not sure what's out there to combat this. I would suggest checking a local Stanadyne Injection Pump rebuilder or maybe a larger local truck stop.
    Real trucks don't have spark plugs!
  3. Heavymetal
    Mar 30, 2001
    936
    Oregon
    Bummer, I was hoping diesel was more stable than gas. Oh well, thanks for the info.
    Mike.
  4. mrivan
    mrivan 1/2 ton status
    Sep 10, 2000
    123
    Coastal Mts. Or.
    Fill your tank almost full so to cut down on condensation then add a diesel stablizer avaible at any tractor shop or big auto parts store. I have two older Mercedes diesels and use different additives to stop alge growth ,remove moisture, raise octane, and clean injectors. Find someone that works with diesel engines every day ,they can give you a wealth of information about the right additive for each fuel problem.....
    Mrivan.......
