stork ford arm vs. the skyjacker piece
Discussion in 'The Garage' started by 55Willy, May 3, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    whos running what and what problems are there in using the stock ford pitman arm??? also pics of each too /forums/images/graemlins/thumb.gif
    -Jeremy
    heres my info, I'll have about 5-6" lift and using histeer so the steering arms will be 2" taller
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm running a Ford Van arm that Waxer turned us on to... No problems. He posted a pic some time ago, I don't have one handy...
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    What year van?
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    4WPW sells the 1004 for $42.
    Junkyard pitman arm may be cheap to buy, but after you have it reamed it will probably cost about the same.
    Plus, the Superlift one is BEEFY.
    -- Mike
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    i thought skyjacker was #1140?
    and why would ya need the stock ford retapered??
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mid 80s Ford full size van. Mine was on an '86 or something...
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Search for Waxer's post, he had all the particulars about 9 months ago...
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    The arm actually doesn't need to be retapered if you run the TRE's (ES2010L and ES2234R), but if you try and run the DLE's (ES2026R and ES2027L), then yes it will need to be retapered.
    Arm costed me 7 or 8 bucks at the boneyard, is just as beefy as the Superlift arm (which I have now).
    The only difference I can see between the two is that the Superlift arm has about 2" more drop. Other than that, they are identical.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Really? The one I got had a TINY hole that no GM truck TRE, much less DLE would fit...
  10. Waxer
    1,857
    Long Beach, CA.
    Yeah I see you got yours off an 86. I've always got them off a late 70's van and yeah the smaller GM end fit perfectly.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    That part number #1104 is a SUPERLIFT part number. /forums/images/graemlins/wink.gif
