straight fan
Discussion in 'The Garage' started by johnathan, Feb 11, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    anybody here runnin a straight fan,no clutch.I have just replaced mine last week hoping it will help with cooling this summer.
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Thats exactly what I run and my rad is stock from a 89 burb, winter and summer she always runs at 200 deg. and that includes crawling in 100 deg. + temp's here in the desert.
  3. dyeager535
    26,980
    If the stock fan was *working correctly* it won't help at all, assuming same fan dimensions/blade count/angle.
    Engine temp is regulated by the thermostat, no matter how fast or how often you turn the fan, you can't keep the engine colder than the thermostat temp. If the fan is turning while the thermostat is closed, you are wasting engine output, most noticeably while the vehicle is moving.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    i have run a straight driven fan a few times, and REALLY hated it.
    the noise and and engine drag created is very bad, it did help with keeping things alittle cooler, but that was also when i had a bad radiator.
    My opinion,,"it sucks":p:
    just fix the cooling system with either a bigger or newer radiator and new thermostat.
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    well i had installed a 3 row radiater and it cools fine as long as I'm movin along,but if I'm creepin around the temp wants to climb on up I have a lower temp thermostat and tranny cooler.It just scares me when it goes to climben,thought a straight fan would help a little
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like the fan clutch is just worn out. I replaced the one on my Sub last summer and the difference was VERY obvious. It now kicks the fan on while idling in traffic with the A/C running, and I can really notice the loss in power when the fan is engaged. I wouldn't want it to be "on" all the time.
  7. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I have the orignal fan on my 63 impala 327, I don't care much for it. I wish I had something better, but takes away from originality.
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    do you have a fan shroud installed? and what size thermostat are you running?
  9. dyeager535
    26,980
    And what kind of temp are we talking about?
    No, it shouldn't "climb up" past around 195*, but if you've got a lower temp thermostat, you'll likely have a hard time keeping it at the rated temp at idle.
  10. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    according to my guage it opens around 150 yeah I have a shroud on there
  11. dyeager535
    26,980
    Well, the gauges should be used only as a relative measure unless the accuracy has been confirmed. If you are certain it's 150*, then climbing even 50* isn't hurting anything. But 150* is way too low IMO, I'd suspect the gauge is at least a bit off as 150* t-stats, if they exist, can't be real common. :) 160* is the most common low temp stat you'll see.
    A cooler t-stat is a band-aid fix for an idle cooling issue, fan (and ambient temp + cooling system efficiency) is what keeps idle temp what it is.
  12. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    I don't remember what temp the stat was,but I do remember it was the lowest one available at Advance.If I'm creepin through the trail in warm weather it will climb up around 210(by my gauge).Not at all worried about engine,just tranny.I have installed a cooler,not a huge one,so 210 makes me a bit worried.
  13. 4xcrazy
    Oct 31, 2003
    9,472
    5
    The only times i personally have had problems with creeping temps like that when idling, crawling, or or whatnot, was either cause by a bad clutch not engaging, or the radiator was old, and several if not most of the rows were rusted shut and not allowing for full flow.
    I DO still have this problem now, even with the brand new heavy duty fan clutch, and 4 row radiator, but i am certain it is because i have yet to find the correct fan shroud for it.......running without it at the moment.
    Only heats up on the trails though, hasn't done it on the street driving in traffic yet.
