STRANDED - WON'T START!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jul 24, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    STRANDED - WON\'T START!!!
    Ignition module is good
    Motor cranks fine
    Primary side coil = 1 ohm (???), secondary side = 5000
    Battery voltage = 11.99
    PLEASE HELP!!! ANY IDEA'S???
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: STRANDED - WON\'T START!!!
    The resistance on the secondary side of the coil seems way too high. An ohmmeter uses direct current to make it's measurement. It should read very close to zero ohms on either side of a coil.
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Here are a few ideas:
    Are you getting a spark at the plug? (check distributor shaft, wires, terminals, rotor, module,etc.)
    Have you got good compression? (Timing chain, lower engine block, timing problems)
    Is there Gas getting in the engine (Carb, fuel pump)
    Other than that, FUEL + SPARK + PROPER SETUP = RUNNING ENGINE !
    Good Luck!
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    BINGO!!! You got it! A bad coil...replaced it with an Accel Coil ($30) and it started right up!
    Thank you!
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Actually the secondary side was fine (measured between the + side, and the coil wire output) MSD tells me that the secondary should read between 4900-5000 ohms so it was right on the money. The PRIMARIES however (measured from + to -), were way out of spec. MSD says between .71-.80 ohms is good. Mine read at 1.0 ohms. Dropped in a new unit, and she started like nothing ever happened! /forums/images/icons/smile.gif
    Thanks for the help all!
    -Dan
