Strange 14BFF (pic)
Discussion in 'The Garage' started by MTBLAZER89, Feb 9, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Found this on Pirate. My buddy is looking for a C&C 14BFF is this what one looks like with the backplate flanges way in there? He is going to run C&C hubs as well with discs. Will the flanges need to be moved or are they ok right there?.....if not does anyone know how you move them?
    Thanks.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Contact Grady at Grady's Extreme Off-Road! He shoulg be able to give you the answers your looking for. He deals with major fabricating and modifing of axles
    Bill
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That looks like a dually two wheel drive unit to me. The flanges are way in to make room for the dually set up and I say two wheel drive because of the way the shock mounts are rotated downward as they are.
  4. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    My 14BFF looks just like that with the hubs off. The shock mounts are EXACTLY the same. Oh yeah, its the factory 14BFF in my 86 GMC K3500.
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    i've got one in the garage right now that has shock mounts exactly like that. It was from a 2 wheel drive truck. It wouldn't go in mine without moving the shock mounts upward. The shock body hit the mount/axle tube and wasn't even close.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I've only ever seen shock mounts like that on 2wd 14 bolts.
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I got my 14bff from a '76 2wd and it bolted right into my '89 Suburban with no problems. hmm, that looks like it either goes to a newer style truck or a different one all together?????
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Yeah I know it's from a 2wd, but is it a C&C and do you have to move those backing plate flanges with C&C hubs to run discs?
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    anybody?
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you should be able to dry fit/mock test fit everything in order to get measurements to see where the backing paltes need to be attached at on the axle tubes
    someone who has doen all this needs to eleborate on how exactly /forums/images/graemlins/laugh.gif
    good luck
    oh and those shock mounts look normal to me too, 73-up staggered style, common normal
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Guys, the shock mounts on ALL 1 ton 14FF axles are lower hanging like the 2wd's. Its the 3/4 ton 14FF's that have a higher and lower hanging shock mount. Thats it. All 1 ton rears have the same length shock mount. /forums/images/graemlins/waytogo.gif
  12. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If they were not in the way, I would just put 2 new flanges on there and leave the old ones.
    Yes they will need to be moved/replaced for the disc swap.
  13. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I agree. The flanges in the top pic are obviously not in the same location as the ones on my 3/4 ton axle.
    /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  14. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Well the hubs are 2" narrower than a SRW hub so that looks like the flanges are about 2" farther in too. So with C&C hubs will disc brackets work?
    To move those flanges just grind the welds??
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Or have a spacer made. I believe around 2 3/4" spacer would be the right width to fit to the SRW bearing hubs. /forums/images/graemlins/thinking.gif
  16. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Yes, then use a BFH.... IF there is the slightest chance you may want to run a dually set up, leave them on there. /forums/images/graemlins/whistling.gif
