Strange drive train noise after long run
Discussion in '1982-Present GM Diesel' started by marcus, Aug 1, 2003.
  1. marcus
    marcus Registered Member
    Dec 21, 2001
    65
    England UK
    Guys,
    Asfter a long run (20miles+) at 70mph+, when I slow down at a junction and stop, as I pull off, there is a clunking/craking noise form underneath the truck...and some associated vibration...this only goes on for a second or so...then it's fine.
    This also never happens driving around town...it just seems to be after no hard runs on the motorway....any ideas?
    Cheers
    Mark
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    my guess check the fluid level in your t case if ok then check the amount of play in the rear output shaft
    good luck
  3. marcus
    Dec 21, 2001
    65
    England UK
    thanks for that....now...I'm going to show my ignorance...what fluid should be in the t-case, and are the fluid check holes and drain holes pretty obvious...?
    Thanks...
    Mark
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    ATF fluid inside
    There should be a plug at the top of the t case. If I remember right it was a big plug and I had to get out the big adjustable wrench to get it off.
    The drain hole is at the bottom of the tcase, right straight down from the top check hole!!
    Don't worry about showing off that you don't know anything. Bet you could go back through all these experts posts and find them asking stuff!! /forums/images/graemlins/thumb.gif
  5. marcus
    Dec 21, 2001
    65
    England UK
    thnaks for that...I'll have alook this weekend and let you guys know how it turns out...
