Strange front end noise....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Apr 24, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Okay...everytime I turn into a parking space, a weird noise (kinda like the sound of tires on a really slick shop floor) comes from somewhere in the front end (I believe) when I straighten out the tires. But this noise happens on asphalt and concrete! The tires aren't slipping, which is what it sounds like. Any ideas as to what to check?
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Maybe a squeakin belt? Or Power Steering pump?
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Sounds like ball-joints to me... Check to see if they are greaseable, if not they are more than likely the OEM parts. If you have to replace them, I would recommend you let a shop do that one... but that's just my opinion!
    <font color=red> Check out my rig @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
    <font color=red> I Love My Blazer! </font color=red>
  4. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Yeah it sounds like something is lacking grease...grab yer grease gun and get everything that is greasable under the front end and see if the noise is still there.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Hmmm...ball joints. That could be why it also pulls to the left when I hit the brakes and why it wanders AND what that funny clunk is underneath. I didn't think ball joints could make a rubber squeaky noise, but I've been surprised a lot of times! Thanks!
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    What kind of funny clunk?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  7. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    You just answered your own question. Your balls are loose or worn out, take your pick :)
    One From None
  8. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I think the solution would be a new Dana 60...[​IMG][​IMG]
    That should get rid of the noises!
    Rene...hates ball joints
  9. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    It's a dull thud...like a broken shock mount. I thought that was what the thud was when i hit a bump, but it could be bad ball joints too. I haven't gotten under there to look yet.
  10. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Check the ball-joints like you check for wheel bearings. You may wan to get someone else to wiggle the wheel while your back there looking.
    And the ball-joints are not bad to change your self. YOu will need to take the knuckles to a shop with a press though to press out the old and in with the new.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-TCI 700R4-241-33" BFGs-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    Oh no, not loose balls!
    If the ball joints are really loose, the squeaking could be the knuckle rubbing against the rubber grease boot of the joint.
    You can also get some squeaks from any polyurethane front suspension components when you turn the wheel. As the front wheels turn, the whole angle of the front end changes because of the caster built into the axle. This can move your springs or sway bar just a little and give a squeak.
    But it does sound like you've got bad ball joint(s) or else a bad tie rod end/drag link end.
    <font color=green>"MAN THOUGHT HURT BUT SLIGHTLY DEAD" --Providence (R.I.) Journal</font color=green>
  12. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    So is this a unanimous vote for bad or need to be greased ball joints? LOL!!! I'll take a look. I've done ball joints before...I ain't scared of'em! LOL!
  13. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, they are all bark and no bite. LMAO!!!
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would grease everything up really good and see if that helps
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  15. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Dang I hate it when my balls get worn, loose or worn out! [​IMG]
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  16. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Well, upon inspection, I found the driver's side upper ball joint bad, the passanger wheel bearing needs grease, and possible a warped rotor. I tried throwing some grease into the ball joints (all of them, both sides) and they are clogged. So, out with the bad, and in with the good. It'll be a little while (a couple of weeks) before I replace them. Thanks for your help!
  17. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    check your steering pump sounds like you may have some air in the system.. the other things you just mentioned may be the bolts for your steering box eaather loss or the frame may be cracked.... I just had to tighten the bolts on mine.....
    C'moe
    <font color=black>the blazer is "Back in Black"
  18. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Never heard of bringing the knuckles to a shop to have them pressed out and back on. Just use a pickle fork and a BFH. Works pretty slick.
    Why do people keep calling it a Bronco!!!!! [​IMG]
