Strange fuel problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ankarback, Feb 21, 2006.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    Hi !
    My suburban have recently developed a strange fuel problem. When going up steep hills the engine act like it's starving on fuel and then stops. To get it started again it has to be towed down to level ground. It's just like it's sucking air in the fuellines from somewhere. The carb is a quadrajet but I don't think the carb is the problem because the fuelline is completely dry when the truck stops, I've checked that. I've also noticed that the fuel gauge have started to sway from empty to full when on the trail. Can that have something to do with it?
    Anyone got an idea where to start looking. It's very annoying when you have to be towed downhill especially if you have trucks behind you on the trail :doah:
  2. takebackthepower
    takebackthepower Registered Member
    Feb 9, 2005
    33
    Redlands CA
    i have a 82 Jimmy and it was having almost that same thing, i had no clue what it was then someone told me to clean my fill filter, and when i did it never had the the problem again.:D
    i dont know if your's is the same kindof deal, but you might want to look into that...
    hope i could have been of some help
  3. dyeager535
    26,980
    Coupled with the fuel gauge weirdness, might be looking at a broken sender. I've heard of them breaking off inside the tank, which could mean the pickup tube is not connected very low in the tank anymore.
    Also, have heard of rusted fuel lines and/or bad connections leaking just enough to negate the pumps effectiveness.
  4. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    I didn't know the fuel pickup tube was connected to the sender, that might be the problem then. Looks like I have to lower the tank and check it out :doah:
    Thanks for the help.
