Strange noise
Discussion in 'The Garage' started by jekquistk5, Aug 11, 2004.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    Now that my blazer is on the road, ive been hearing a strange noise. It sounds like metal on metal contact! It happeneds at random times too thats the confusing part. it seems to be when i let up on the gas or floor it. Clank, i thought it was my spring hitting the frame but i checked my shackles and looked for dings or scuff marks in the frame... Nothing. I do not think it is my trans because its not durring shift points at all, Its kinda hard to describe because it happens at differnt times everytime. And its a loud clank too! Any help, or atleast another starting point?
    Thanks,
    Jess
  2. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I'd check u-joints. I also had a noise that led me to the rear pinion nut that was coming loose on my old 10-bolt.
  3. jekquistk5
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    I'll check the nut, but i have all new Joints everywhere, rear , front, and both on the front axle!
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Maybe the motor pulley hitting the frame ? Saw a post on that in the last 2 weeks . Look at the fan shroud and see if it has rub marks which would indicate the motors moving .
    or
    Does the steering get affected at all ? When my gov loc went it banged sometimes until it let go finally . When it banged it affected steering just like a locker would . That is if your 10 bolt is gov locked . Or maybe you installed a lockright or something ?
    /forums/images/graemlins/k5.gif
  5. jekquistk5
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    Nope not gov locked, its open! My steering is a little loose, but i know thats the steering box now. It pulls to the right a little but im prety sure that thats because the right caliper is sticking! Im puttin on new calipers this weekend so maybe i will find something interestin! Any other suggestions?
  6. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    How about your body mounts, Motor mounts, trans and tranfer case mounts? Or possibly your bushings. /forums/images/graemlins/dunno.gif
    Have you done any recent mod's or has it just all of a sudden happened?
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    [/ QUOTE ]here
    Ah, the effects of broken motor mounts, accompanied by many strange noises of course.
  8. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    U'- joints
