Strange rattle around torque converter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Dec 22, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Hey all-
    Just got a new muffler and tail pipe installed on the Burb today, so now I'm noticing all the other wierd noises its making. There is a rattling noise... which sounds like its coming from under the rear of the engine, right where the TC is located. Could this be a bad TQ, or should I look at something else?
    Thanks as always.
    -Dan
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Is the dust cover for the TC loose?
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I took it off to inspect this problem, same noise.
    Here are the specs:
    96 Vortec long block
    Unknown flywheel (application wise)
    Presumably OK factory TC
    TH400/241
    The flywheel is where I get interested... I just called Autozone and found out that they don't carry the flexplate for the 96, but they do for the 87-91 350... which means that they are different...
    Anyone out there know if the 350 Vortec's are balanced internally or externally?
    Thanks,
    -Dan
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    check the converter bolts.....
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Checked already... They are tight. /forums/images/graemlins/confused.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Once again, I would about bet that you have a broken flexplate. They commonly crack around the bolt holes that hold it to the crank. Sometimes you can see them if you look up there carefully with a flashlight.
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Ok, so the question is if the 96 flexplate is different than the 89...
  8. dyeager535
    26,980
    I don't think the balancing of the first gen(?) smallblock 350 ever changed. Vortec 350 lower end is the same as any previous, short of the one piece rear main.
    The previous ones may have used dual converter bolt patterns to ine up with a TH400 or 700 or 200, but I'm just speculating on that.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    ALL SBC's except the 400 up until 1985 were internally balanced, starting in 1986 when GM introduced the 1 piece rear main seal engines GM externally balanced the rear only of those engines. From the info I have on hand GM only says 1985 and older or 1986 and newer for flexplates.
  10. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Cracked Flexplate
  11. dyeager535
    26,980
    If the external balance thing is correct, which now that I think about the '87 305 flexplate I have here probably is, then there would still be no reason for a flexplate break the years he was told, correct?
  12. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    The flywheel is cracked around the bolts.
    -Harrison
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That would be correct, I am looking in the 2002 GM performance book and it only has options for 1985 and earlier or 1986 and later. There are a couple different variables of each one but only pertaining to the TC bolt pattern and also 153T or 168T count.
  14. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Just called Napa, and they list PN 6005062, for $37. Is there a heavy duty version I can replace the factory unit with? This flexplate was AOK when I installed it just this summer... /forums/images/graemlins/blush.gif
    What makes it crack like that? Hell, its not like I tow a 8000# trailer with this truck all the time or anything... /forums/images/graemlins/rolleyes.gif
    -Dan
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look for an SFI approved flexpate. They're thicker and tested to take a lot of abuse. Summit has quite a selection for around $50. /forums/images/graemlins/cool.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They crack all the time because people don't replace them when they replace the engine. It's called a, "flex plate" for a reason, and they eventually break from probably all the fatigue of flexing so many times. Either way, if you want a super heavy duty one call the mail orders and get yourself one of the super expensive ones. I personally think that a new one is all ya need though. A regular new one will be good for another 15 years or so. /forums/images/graemlins/rotfl.gif
  17. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
  18. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Awwww crap.
    This smells like work. /forums/images/graemlins/eek.gif
  19. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    And if we use history as a teacher, you guys will do it at 3 AM, in the driveway, during a blizzard, wearing shorts, and will somehow manage to drop the tranny off the jack at least twice. /forums/images/graemlins/eek.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
    Awwww crap.
    You pu$$y. Get over there and help Dan out. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
