Strange temp gauge
Discussion in 'The Garage' started by K10bolts, Mar 21, 2005.
  1. K10bolts
    K10bolts Registered Member
    Feb 8, 2005
    35
    Big Rapids, Michigan
    I have a strange problem with my temp gauge in my 83 K10. The gauge only registers when the key is in the off, or accessory position. If I turn it to run, the gauge zeros out. I'm really stumped.:crazy:
    Anyone have any suggestions on where I should start my troubleshooting?
    Thanks, Matt
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Sending units bad.
  3. dyeager535
    26,975
    You can unplug the sending unit wire, with the key in "run", ground the wire. Gauge should peg out if that is all ok.
  4. K10bolts
    Feb 8, 2005
    35
    I have tested the sender and it is good. The problem is somewhere else in the circuit. I will have to check the wires and the circuit board under the dash I guess.
