Strange Thump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chockley, Jun 14, 2002.
  1. chockley
    chockley Newbie
    Jun 14, 2002
    I have a 1990 4x4 kblazer with a 350 and a 10 bolt rearend. I have no lift yet. On hard acceleration I get a thump in the rear when I let off the gas. I have checked my springs for cracks, changed U-joints, but I can't find the noise. The only time I can make it happen is when the truck is in motion. Does any body have any ideas is this normal for blazers. It sounds like sombody hit the bottom of my truck with a hammer whenever it happens.
    Any help would be appreciated thanks
    chris
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Check your transfercase bolts x-member bolts and make sure they're tight.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Also inspect your motor and tranny mounts to make sure they are tight and in good condition.
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    that sounds alot like motor/tranny/t-case mount to me. Just be sure not to pry on the pans when you're checking them cause you might end up with a slight leak /forums/images/icons/grin.gif
  5. beachinblazer
    beachinblazer Registered Member
    Apr 15, 2002
    20
    It might also be something internal to your differential. One night i made a quick turn and hit a curb with one tire and blew out my spider gears (i think) and the posi wasn't doing too well either. Anytime i drove with it, it made a loud thump noise after accelerating.
