strange turn signal problem...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Sep 21, 2005.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well on my way home from work tonight I noticed in the reflection of the car in front of me that my turn signals were not blinking. The lights would come on bust just stay on. there are no lights burnt out. When I turn the hazards on, every thing works as it should...My first guess is the thermal blinker module...but thought I might get some ideas on here...
    Chris
  2. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    swap the flasher with the 4 way if same and retest. :wink1:
  3. dewster
    dewster Registered Member
    Jul 21, 2003
    31
    corona ca >> austin,tx
    check your trailer wiring sometimes these get bare and ground out causing all kind of weird problems with the brake lights and turn signals :wink1:
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    yup, sounds like a bad flasher
  5. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    or you missed a bulb be sure to cheeck them all including side markers they must all work.
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Don't forget to check your blinker fluid.. I have a leak in mine and I have to refill the resevoir every week or so. :wink1:
