strange wipers
Discussion in 'The Garage' started by blazeonchevy, Jul 14, 2006.
  1. blazeonchevy
    blazeonchevy 1/2 ton status
    Jan 13, 2006
    401
    san antonio tx
    alright so i was working on my truck to make it street legal when the wipers messed up. first they came on and wouldent go off. then the went off but wouldent turn on for anything. then i put a different switch in.now they work but when i turn them off they cycle once then go right to the middle. they dont bother me much but its sortof annoying to be seeing a wiper blade right were you are looking all the time. oh and sometimes if im careful i can nudge the knob to the left and it will move them down a bit. but if i do it too much they cycle again and go to the middle. im not quite sure what could cause this.:confused: well any advice would be cool. thanks -sam-
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There is a part on the motor (can't remember the name0 but it is what makes the wipers return once turned off. Might want to check with your local parts store and i'm sure they'll know what i'm talking about.
  3. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    the "park" switch...
    There are some "points" under the plastic cover over the washer pump that often corrode,and cause the wipers not to "park" correctly...cleaning them might help...
    I've had "ghost" wipers in my 79 C10 since I've owned it..every once in a while they do a "sweep" of the windsheild ,then park again!..it has "delay" wipers,I assume its the control module that is to blame..it does it mostly when I step on the brakes,sometimes for no reason at all--it can go for weeks without doing it!...since they work fine on "low" and "high" speed,I'm not touching them!..I cleaned the contacts,and I might try adding a ground wire to the motor body..but I'm doubtful that it'll help any..:crazy:
