stress fractures
Discussion in 'The Garage' started by Icemanf4i, Jan 13, 2006.
  1. Icemanf4i
    Icemanf4i Registered Member
    Jan 8, 2006
    30
    reno, nevada
    is there a way to reenforce or fix stress fractures on the tail gate along the top corners where the window drops into the tail gate. I noticed a very small fracture starting on the left side of the gate and i want to fix it before it gets worse.
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    got a welder?
    j
  3. Icemanf4i
    Jan 8, 2006
    30
    reno, nevada
    no i couldnt weld it if i had to but if that is what it take i will take it and have it done would a machine shop or a welding or body shop be the best ???
  4. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    I would say body shop
  5. dyeager535
    26,979
    My idea would be to reinforce that from the inside...welding in a piece of metal that spreads the load around.
    I've got a tailgate in my backyard from an early 80's truck that has no cracks in it, I'm not sure exactly why MOST crack though...we know there is a lot of movement, but I think that it's got to do with the glass and it's fit in the shell. Truck gates don't crack.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd treat it like any other crack. Drill a small hole just beyond the end of the crack, V it out, weld it. Being its a body part then I'd carefully grind it smooth.
  7. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Or you could spend countless years searching for one of the 8 known to exist that have no cracks. There were 9 but I found one of them last year!
  8. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
