stress on a 350
Discussion in 'The Garage' started by 83' k5, Feb 5, 2006.
  1. 83' k5
    83' k5 Registered Member
    Jan 31, 2006
    11
    Northern Indiana
    I was wondering how well a 350 will do pushing 40" 13.50" tires. Do I need to worry about over working the engine while driving down the road.
    I was possibly thinking about upgrading the cam until I get the funds to upgrade the engine. I have been told rv cams are good. What are your opinions on this.
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    For 40 inches of tire that should not be a problem if the gearing is cool. For 40's, i would run a 5.13 or maybe a 4.88 nothing numerically lower and you should be fine.
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    its all about gearing. The only thing where 40s will really "strain/stress" a motor is the fact that they are heavier, its a lil harder to get the tires turning initially. If you have it geared right, you won't be able to ever really tell.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Its all about the gearing.
  5. 83' k5
    Jan 31, 2006
    11
    Northern Indiana
    how do I tell what gearing I have right now. And is it hard to change it. (remember i am new to the whole scene:crazy: )
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Look for a small metal tag on your diff cover.
    or
    Look on the side of your ring gear for the ratio
    or
    Count the number of teeth on your ring gear and number of teeth on your pinion then devide. (ring gear / pinion)
    Gear swaps are easy if you know what to do and have the proper tools, easy top screw up if you don't.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a quick way to tell... if you have 6 lug nuts, its probably not low enough.
    BTW, welcome to CK5! :waytogo: what part of Northern IN are you from? i'm in Elkhart.
  8. 83' k5
    Jan 31, 2006
    11
    Northern Indiana
    Thanks for the welcome. I live in Cromwell. South a ligonier a few miles. I have 8 lugs nuts. It is a gm 14 bolt 3/4ton. It was already on it when I got the truck.
  9. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    4.56' work too.
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Like mentioned, its all in the gearing. I really wouldnt worry about the strain on the motor, its the tranny thats gonna be screamin at you without the right gears. There is a small chance you have 4.56's which would be fine for a 40 tire. Anything else smaller (numerically) and you should regear.
