stretched timing chain?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, Jun 3, 2000.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I went to set my timing and noticed it was about 8 degrees advanced before i started. I set it to 0 degrees and drove it around for awhile. The truck had poor excelleration and hesitated a little bit when i'd start off from a light. My stepdad suggested it was advanced by the previous owner to compensate for a stretched timing chain. i set it back to 8 degrees and it drives better with no hesitations and no poor excelleration. Is there any disadvantages of having my timing advanced that much? The truck has 111,889 miles on it.
    J.D.
    88 Gmc Jimmy
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    It might run a little hotter that way, and gas consumption will be a little higher as well. I had the same problem. I replaced my timing chain (which was stretched) with a new double roller. I compared the old and the new, I hung them on a screwdriver side by side and the old chain hung an inch lower than the new. All is good now.
  3. 79Cheyenne
    79Cheyenne 1/2 ton status
    Feb 19, 2000
    116
    Atlanta,GA
    I may be mistaken but shouldn't the timing be set for 8 degrees advance?
    <font color=orange>1979 BLAZER Cheyenne[​IMG]
  4. Zack
    Zack 1/2 ton status
    Feb 18, 2000
    329
    IL, USA
  5. Waxer
    1,857
    Long Beach, CA.
    Isnt it supposed to be set at 8 degrees BTDC?
    isnt anything before 0 Advanced, and anything after is retarded. or is it the other way, damn, you all got me thinking and my brain hurts from the brewskies.
  6. MudRebel350
    May 20, 2000
    324
    N.J.
    it says on the tune up decal 0 degrees. Im only going by the procedure.
    J.D.
    88 Gmc Jimmy
  7. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Better to go ahead and replace it, if you have never had the headaches of one jumping time, you don't want them...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  8. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    0 degrees just doesn't sound right to me. My '73 is set at about 14 degrees and runs great. I've had other vehicles that I've went as far as 40 degrees advanced, but never seen anything that ran good at 0. I'd say stick somewhere between 8 and 15 degrees.
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    He has an '88, and it has computer controlled advance. You have to disconnect a wire that disables the computer advance, and then set the timing to 0 degrees. My question is, did you disconnect the wire before you checked and set the timing?
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  10. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    That's right! You need to unplug that computer advance wire. Also, I have an 89 and according to the sticker it should be at 0 degrees BTC. Right now it is at about 4 degrees BTC and it pings a little but runs strong.
    10 BOLTS O' FUN
