Striaght or bent draglink for crossover which is better and why???
Discussion in 'The Garage' started by backyardbuilt, Jan 2, 2003.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I'm getting ready to do this, my knuckle is out being drilled, I got the 2wd box, still looking at arms (not sure if I want to try and do hysteer). So whats left is the draglink and of course the pitman arm wether or not to get a dropped one depends on how you guys answer the question at hand. Thanks for all input to this question. Ryan
  2. Grim-Reaper
    7,385
    Atlanta
    Straight is always stronger then bent.
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Depends on how much lift you have. My reason for installing a bent draglink was because I have 6" of lift and still have the factory crossmember. I needed the clearance. Also, Im not sure how much angle you can get with tie rod ends if you were planning on using them. My draglink is more than strong enough to withstand bending.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got the bent rod from ORD and its plenty beefy. I have a 6" lift and the stock crossmember.
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    People use bent draglink to clear the factory engine crossmember. They are much thicker than the factory draglink and, even with the bend, much stronger.
    However, a straight one is, logically, better. Yes, angles on the ends will be worse, but you can adjust it without removing the ends.
    I bought a new engine crossmember that allows the use of the straight draglink. It was, I think, $150. My factory crossmember was cracked as are many others I have looked at.
    It ends up being your choice.
    I will be using a straight draglink.
    -- Mike
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you are having a problem with using a bent link, look at Jeeps and Dodges. They come from the factory with bent links that are weaker than most aftermarket links(like Rockstompers Rock Rod links)...
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I run a bent draglink from Rockstomper and it works great!
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I also have a bent draglink from Rockstomper. No problems.
    Don't think I'll ever bend it-
    When I had the straight drag link, my ends would get all jacked because of the severe angle and when you're flexing, it make it even worse. By running a bent drag link, you ends will be straight.
    review of Rockstompers-
    http://www.off-road.com/chevy/reviews/rockstomper
  9. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm running a bent draglink to keep the TRE's at a straight angle and to clear the crossmember. I'm running about 6.5" of lift. So far no probs, if its built right it shouldn't matter. Mine is made out of solid steel drilled and tapped. It seems stronger than those weld on fittings for tubing.
  10. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Who's drilling your knuckles? I need one done too.
  11. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you use drag link ends you won't have to worry about the angle much at all! They can handle A LOT more angularity then a tie rod end.
    Then running a bent link just comes down to will it clear all you bits?
  13. Shawn
    1,753
    5
    5280'
    I have also tried the drag link ends and I still had issues with them under full flex.
    They do give some more angle but not much.
    Steve's running them on his hi-steer setup but has been having problems breaking them.
    I think since they are longer, they are weaker. He's going to the shorter tie rod ends now.
    Edit: Steve is still using the drag link ends on the the drag link. Tim redesigned the drag link bar and hopefully should fix Steve's problems.
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm about halfway through that conversion now, and I decided to go all Tie rod ends after seeing Steve's luck.
  15. CK5
    May 19, 1999
    21,625
    702
    CO
    I think that the drag link ends on the drag link will be fine, never had a problem with them. My problem was with the drag link ends on the tierod.
