Striped bolt holding flexplate on the crank, please help!
Discussion in 'The Garage' started by dawson444, Nov 22, 2003.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Well I am stupid I know, but I tried to get my flexplate off. Only thing is I put a 9/16 on it instead of a 14mm. So 2 of them are striped on there. A 14mm socket just slips and a 13mm won't go on there. Please help me! Thanks!
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if cant beat on an oddball sized socket, then will probably have to weld a nut to the bolt head to remove it
    if you are talking about the bolts that hold theplate to the crankshaft snout then they arelarger than 9/16" and 14mm anyways
    good luck
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    try a cheap 12 point half inch socket and hammer it on..might do the trick, you can always grind the heads off, pull the flex plate off and thread the bolts out with vice grips..
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  5. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    twist sockets ? huuum interesting , never heard of such a thing, does only sears make these ? or just carry them ? or ?
    anyone got a close up pic of one of these sockets ? im very curious, hmm,..
    183 bucks a set, hmm they better work damned good!
    do they ?
    oh and dawson, i like your avatar, hehe, did you just simply paste the URL of that into avatar line, or ?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think they're 15mm.
    I was gonna change the rear main in my '87 but they were stripped and wouldn't come out so I left 'em. Thank God it doesn't leak.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    here's a whole page of different ones...
    http://www.usatoolsplus.com/catalog/twist_sockets_sets_150217_products.htm
    not sure if you can see the spiral cut of them. they work killer... a google search brings up quite a few...
    sorry, for the snap on link, these are a little cheaper. the Craftsmen should be fine too. i just happen to own a lot of Snap On and had the link handy.
  9. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    i find using a small plumbers pipe wrench can get most of
    those stripped bolts out, even if the bolt is completely
    rounded out it will still grab, just like it does a pipe,
    and there very cheap,
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I bet heat and an impact tool (ya know, the one you hit with a hammer and it loosens stuff) would probably work before I'd try anything drastic like a pipe wrench.
    Worst case you can grind it flat and drill the bolt out, but I'd be it's hardened and will be a bitc* to drill.
  11. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I will try all of these ideas and see what works. Thanks for the tips. As far as my side picture is concerned, its an animated gif and I just cut and pasted a link to it. Thanks again!
