Stripped adapter hole in sm465, Heli-Coil it?
Discussion in 'The Garage' started by fortcollinsram, Nov 24, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I dropped my t-case tonight b/c I needed to replace the adapter between the sm465 and 205 b/c of a nice crack that developed and the fact the the tranny was leaking from the rear...I pulled the adapter to replace it with a different one...As I began to tighten the adapter bolts to the tranny, I noticed that the very bottm bolt hole is stripped. I decided to continue with the install but as soon as I removed the jack form from under the tranny and let the weight rest on the adapter, the adapter pulled apart from the tranny at the bottom...So I called it quits for tonight b/c it is cold and snowing. So do you think if I get a Heli-Coil in there that it will hold? AFAIK, that bottom hole is blind...Do you think a Heli-Coil will hold well enoguh...I think some of the stress on that bolt will be relieved when I attach the 205 again...
    Chris
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    I had almost the same problem on my 700r4. Nomatter how tight i got the bolts they kept comming loose, finaly they stripped and i put heli-coil in it. It held up just fine, till the front u joint went(going down they expressway)and broke the trans case and transfer case tailshaft. I think That i should hold up just fine. but i also had a 208 not a 205.
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yeah, but you had only 4 bolts holding the adapter to the tranny...I have 8 and the tranny is case iron and not aluminum...I think it is strong enough as is but I need that last bolt in there so my tranny doesn't dump its fluid on a continual basis...I will try the Heli-Coil tomorrow when I get home form work...I froze my ass off tonight only to not even finish...oh well...Thanks for the input buddy...
    Chris
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    hey there, hows it going, i hear you striped it out, a heila coil should work, we use them all the time at auto tech school. when you get the bolts back in, try useing a big of blue or red loc-tight, that is what works from what ive heard. good luck on that. i wish you luck. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    did you use a gasket between the adapter and cases?
    I think the snapring relief may require the gasket to prevent the snapring from bottoming before the machined surfaces meet.
    just a theory on adapter leaks
    think I will go mic the spare, looks like a gasket is definitely required or the adapter will not seat
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Excellent point MJ...I think that was the reason for the adapter leaking originally...I used RTV instead of a paper gasket...I do faintly remember the adapter rocking from one side to the other, as if it were hung up on something in the middle...I used a paper gasket this time but the bolt was already stripped...So tomorrow I will get some gasket material from work and maybe double up the papaer gasket with a light smear of RTV and HeliCoil the stripped hole...
    Chris
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have had mine apart so many times and that is the best theory I could come up with to explain the thickness of the massive amount of sillyputty required to seal the dam thing.
    looks real professional /forums/images/graemlins/rolleyes.gif
    bet that is what cracked the adapter
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    YEa i agree a helicoil should be fine they acually claim it is stronger then origianel ( and they couldnt say it if it wasnt true right ) /forums/images/graemlins/rotfl.gif
    i use them when ever needed and they havnt let me down yet
    best of luck to ya hey has ski season started yet ????
  9. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    If you have a good tool store or nut & bolt shop in your area, go down and see if they have some things called Gard-Serts. It looks like a bushing, with threads inside and out. You drill an oversize hole for the O.D., then you put a bolt in the Gard-sert and power thread it in there.(If you have enough material to hold it). If you think a heli coil is too weak, check these things out. I'll TRY to find a link.
  10. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yea, the ski season is pretty much in full swing here...I want to get my truck done tonight after works so I can go to Steamboat tomorrow...but we'll see....Thanks for the help gang...I will use a paper gasket today and heli-coil that hole as I freeze my ass off outside...man, it would be nice if my blazer fit in the garage /forums/images/graemlins/pimp1.gif
    Chris
  11. GMslave
    Oct 3, 2002
    113
    Flint, Michigan
    Okay, I found something similar. www.timesert.com
    I thought the ones we use here at work were called Gard serts, but I can't find them. These look like the same thing. A search under 'thread repair' brings up a few more too, for those of you who will eventually strip a thread that a Heli Coil won't be strong enough for. /forums/images/graemlins/grin.gif
