stripped bleeder.
Discussion in 'The Garage' started by k5freak44, Jun 26, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    stripped bleeder.
    ive got a stripped bleeder that i cant get off, its all rusted up and what not...
    what is the best way to get it off???
    grind downeach side of it and use a crecent wrench?
    or
    weld a nut on the end of it and just use that
    im going to replace it when i get it out anyway but how have you gotten these off
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Bleeder
    Some rust buster, a wire brush, and a pair of vice grips usually works, or if you have a socket just a tad smaller than what it usually takes, hammer that onto it, and get a ratchet on it.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Vice grips are all you need :)
  4. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    its almost rounded out, if vice grips dont work i guess i could always girnd 2 sides flat.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    they will work trust me, I had to do the same to mine
  6. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    You might consider just replacing the whole caliper or wheel cylinder. If its that rusted up then the whole thing might be due for a replacement, and its a lot easier. :grin:
  7. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    weld a nut on it..
    I have had to weld or braze a nut on many bleeder screws on my own and many others vehicles!...vise grips dont always grab good enough without crushing them--if you weld a nut over the bleeder,and let it sit for about 5 minites,the heat will soak into the threads and help loosen it up--I get them out nearly every time that way--if I dont--rebuilt calipers were 11.99 at autozone exchanged!--If I had known that I would have just got them in the first place! :doah:
  8. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    I'd say vice grips and lotsa Dub D 40. That stuff's a life saver. And if all else fails... cut it.
