Stripped diff fill plug
Discussion in 'The Garage' started by BowtieRed, Oct 15, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    durrrr. . . . umm, what should i do? tap a hole in the cover at the same level as the one in the housing?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The part where the ratchet goes is stripped? Is it real clean in there? sometimes cleaning it out some with a small screwdriver or awl will help.
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    you mean the square hole is stripped? or the threads. i would probly drill a hole in the cover like you said. mine was getting bad so i replaced it with a brass plug that has a standard hex nut on it. i dont know why they use those.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i drilled a holl on the dill cover and welded a nut to the back side. put some silicone on the back side of the bolt and installed it. IIRC i used a 5/8" nut.
  5. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Weld a nut to the origional plug and turn her out. Eather get another one or use your new welded nut plug. /forums/images/graemlins/thumb.gif
  6. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    If it is a 14 Bolt, go to a parts store & borrow a 1/2" pipe di.
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    finally got it. tried a punch and 3lbs sledge and just butchered the edges. tried a bolt, grinded the end into a pentagon and hammered it in, nothing just slipped, took the 3/8 extension, again, and put it in so it lined up exactly like it shouldn, corners of extension on flat (or what appeared like it used to be the flat side) and hammed it in with the same 3lb hammer and finall got it. guess, i'll either get a new one, or cut that one for a 1/2" drive. . .
    thanks anyway.
  8. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Now that you have it out to to a plubing supply store and get a standard plug. Either a square drive (outie) or a hex-head.
