stripped hub hex bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Jan 24, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    How should I get out a stripped hex bolt out of the wheel hub? I've tried using a torx bit but that just spun around too. Can I buy a pack of hub bolts for the Warn hubs?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  2. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    You will need to drill down through the center all the way through. Do not drill a hole large enough to remove any threads, ony the center of the bolt. You will then need a bolt extracter which you can buy at the hardware store. This is inserted in the hole you drilled and turned counter clockwise to back the srew out. Good luck,
    <font color=red> Bill, "Shop Rat" </font color=red>
    http//community.webshots.com/user/bhughes85713
  3. dyeager535
    26,979
    Couldn't you just drill the head of the bolt off, remove all the others and the hub "cover" (the piece the bolts hold on, right?) then use vise grips on the stub left sticking out?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dyeager is on the money
    formerly 77chev
    still a jerk though
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Warn has really crappy bolts, don't they? I broke two of them... Spicers have a lot beefier bolts and I was able to get new ones at the fastener store for about 25c each.
  6. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    That's a good idea. So a fastner store sells these things. What a name of a national fastner store? Ya think a hardware store would carry these bolts?
    Mudstud
  7. dyeager535
    26,979
    Not sure where you could get replacements, but if stock stuff works, and you are in a pinch, you could probably hit a wrecking yard for a temporary one. If the bolts suck as has been implied, I'd want to replace all of them with something better!
    Those are going to be hard to find at a chain hardware store methinks : )
    Dorian
  8. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    Another possibility is to take a drill bit that is about the same diameter as the head of the screw, grind the cutting edges in reverse then put it in a drill (make sure it is in reverse) and press hard to the bolt and squeeze. If you go to buy new screw they are called 10-32's ( a #10 screw and 32 threads per inch) Good Luck.
    "We all gotta go sometime.... Race ya"
  9. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    Machine shops will usually have a good variety of bolts, including high grade ones.
  10. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Good thought. I'll probably do that temporarily but I'm thinking I'm just gonna drag both of them in to 4WP and exercize my lifetime warranty. New hubs coming my way and I need to regrease them anyway.
    Mudstud
  11. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    agree with dyeager.
    I just bought a hub bolt for my Warn Premium hubs. You can buy a kit from Warn with a replacement o-ring and 6 bolts for like $6 but you have to order it. I got the hub bolt for like 30 cents. My extra set of hubs are the classic Warns. I'll figure out the size again for both Warn hubs this weekend. If anyone wants bolts let me know what hubs you have and how many you want. I go to that hardware store all the time, if I go next week I'll pick up a few. The ones at the hardware store are much better quality than Warn's.
    '70 K-20 San Diego, CA
    I know, I can't spell!
  12. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    What hardware store do you go to? I've got the 'classics'-?? I guess-chrome round cap with like the black nylon dial. I'm gonna check a machine shop around here too.
    Mudstud
  13. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    It's Marshall's Industrial Hardware in San Diego, CA. It's an Ace hardware store, but they have completely different stuff than any hardware store I've ever been to. They have very high quality hardware. They are a little more expensive than other places but they have everything. The Warn Premium hubs use a 6-32 x 1 3/4" bolt. I still have to dig up a classic hub bolt for size.
  14. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    The best fastener place in the world....FASTENAL. They have stores nationwide. If you go pick up there catalog with all store listings (that's how I found the one near you). They have a packaging plant and a store in Memphis. The store is located at:
    2099 Thomas Rd, STE.14-38134
    Phone: (901)-371-9051
    Fax: (901)-371-9086
    I bought stainless screw from them for my hubs (I used a little rtv to seal as mine were not the oring style). They were cheap. I had to wait one day for them (big deal), but they were like $.06 each!! You could probably call today and pick-up tomorrow. As state I believe they are 10/32 but not sure on the length.
    They have any type of fastener you need, they also custom build fasteners if they are oddball sizes or special purpose. Wes,
    If you read this, this is where I got all my fasteners from for my frame. Saved hundreds over what a regular hardware store charges.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  15. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Wow, talk about coming through for a guy. Thanks Leadfoot...and all other too of course :)
    Mudstud
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    on reassembly this time use antisieze compund
    formerly 77chev
    still a jerk though
