Stripped lug bolts
Discussion in 'The Garage' started by nad, Mar 27, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I have 3 stripped lug bolts on my truck, two in the rear and one on the front. I've heard these are "easy to knock out and replace". But I can't seem to define "easy" as taking the brakes all apart. Anyone know of any special, easy way of doing this? Anyone have any clue how much a shop would charge to do such a service?
  2. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    if you have a 10 bolt rear its easy
    you shoudent have to take the brakes apart just pull the drum off
    for the front you will have to pull the hubs and remove the spindle nut and calaper to get to the back of the roter
    colby
  3. goldwing2000
    goldwing2000 Guest
    Rear is easy, front is a little more involved. ct85k10 is pretty much right on the money.
    If you don't feel comfortable with something as simple as taking your brakes apart, then you probably shouldn't be working on your truck.
    If you're willing to get dirty and save some money, then you could have this job done in a couple hours but do it on a weekend, just in case.
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i was able to remove the one broken lug on the front of my truck by taking off the caliper, spinning the wheel assembly so that the lug was positioned in the area where the opening was from where the caliper would be assembled and then whacked it with a hammer a few times. pulled it out the opening in the back. pretty easy. don't know about the rear, never done that.
  5. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    that would be the easiest way for a single stud, esp if you don't feel comfortable puling apart your hubs. I always just go ahead and pull it all apart when i do mine, its simple enough for me.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    would it make a difference if there were multiple studs? seems you could just pound one out, turn the rotor, do it again, etc.
  7. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    the easiest would be to just bolt up some 3/4 or 1 ton axles that don't have stripped lug nuts :pimp:
  8. goldwing2000
    goldwing2000 Guest
    The only problem I see with that method is properly installing the new studs. How did you do it?
  9. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    there wouldn't be a problem, but just to make it easier to do and properly press in, id pull it apart...then prob just press them im on my 20 ton press. Ive also had some lug studs that you can pound the mess out of and won't properly seat, and yes they were for the right application.
