stripped sector shaft?
Discussion in 'The Garage' started by Jishory, Jan 24, 2007.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i have been outside all day with an allen wrench trying to tighten the stud that threads into the top cap and it will not move at all, i can crank it either way till the cows come home but it wont move up or down one millimeter, i have tried pulling it out but it wont budge. anybody else do this before? :dunno:
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    did you loosen the nut first?
  3. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    yes the nut is long gone, the cap is also off at this point, im just trying to get the stud threaded in and tight
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What exactly are you trying to do? Are you trying to remove the sector shaft? If so take the 4 bolts out around the stud & lift the cap.Make sure the steering pointed straight with the pitman arm removed.
    Harley
  5. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    i had a second steering box where i broke the case so i took the top and tapped it for hydro assist, i replaced the front cap in a few minutes, took the top one off by removing the nut, the stud came with it for a while but then the nuts was off and i twisted off the stock cap, then when i was trying to replace it with the tapped cap i realised that the stud wasnt moving at all
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Once the nut is off doesn't the sector shaft just come out of the top cap? I thought that stud changed the relation of the sector shaft gear to the worm gear. Essentially setting the backlash of the steering box.
    If I am wrong you can kick me in the junk. It is late and I am getting my ass kicked by a Verizon cell phone.:mad:
    Ira
  7. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Sounds like a personal problem :D !!
  8. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    im gonna try it tomorrow again, if it doesnt work ill go get another steering box i guess, im on my 3rd one in the past few months
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You are screwing it in, not out, right?
  10. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    Righty tighty lefty loosey right?
