stripped steering wheel bolt
Discussion in 'The Garage' started by medeng8, May 23, 2006.
  1. medeng8
    medeng8 Registered Member
    May 10, 2006
    18
    AL
    I pulled my horn cover off to put a newer steering wheel on and went I went to remove the center bolt, it came off pretty easy, which I thought was odd. I then noticed that the threads that the bolt go on are almost non-existent and smooth.
    What do I do? Use a tap to cut new threads? I have never done it before, but I really need to fix this as I dont think its safe to drive now.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    find another steering column and replace the whole thing. I think that would be the easiest route to go. then you'd just have to swap in your tumbler or get a column with a key.
    I agree, I wouldn't feel safe running that. And if the threads are gone(smooth) you cant really cut new threads unless you go to a smaller nut.
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Would a heli-coil work?
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Nope, it sounds liek the damage is on the shaft. I would either:
    1. Get a new steering column
    2. Weld the nut back on until I could get a new column
