stripped threads in transmission
Discussion in 'The Garage' started by hans999999, Feb 25, 2006.
  1. hans999999
    hans999999 1/2 ton status
    Mar 9, 2005
    149
    southern connecticut
    The threads of 2 of the 4 bolt holes in the end of my transmission to hookup the adaptor from my np208 to my 700r4 are stripped. One is a bottom hole so i put a long bolt through and tightened it with a nut on the other side. Any ideas on how i could fix this? I was thinking, besides tapping new threads, a helicoil? anyone ever have this problem any fixes? Thanks advanced.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    helicoil or bigger bolts are the only way i know to fix it right.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
  4. hans999999
    Mar 9, 2005
    149
    thanks. tried the bigger bolts before. looks like i need to get some helicoils.
  5. westcoastblazin
    westcoastblazin Registered Member
    Oct 3, 2004
    15
    Same thing happened to me, but the two bottom bolt holes. I used a kit called Perma-Thread, it's the same as helicoil, works great!
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    maybe after its heli coiled ( and this is something I want to do anyway since we remove our chit a lot ) how about using studs in the tranny side . Then you can slide the adapter on and tighten some nuts instead .
    I gotta pull mine again soon just to reseal and inspect it , and may just do that .
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    local small time welder shop guy can fix you up good
    i once had a transmission that when i went to remove the bolts that hold the tranny mount to the case a big huge chunk of the case broke off and it took the threaded bolt hole and half the mounting pad with it, it was crazy, so much corrosion, the bolt was stuck froze in there, snapped the case
    so i took the tranny to the local welder guy and he fixed me all up for 35 bucks, added aluminum to the case there, and shaped it, and drilled and tapped a new hole
    like brand new
    the th350 trans i put in the 82 trans am out here, couple years ago, now in storage
    good luck
  8. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    helicoil works great worked for my buddies 84 blazer same problem kept getting bad vibes
  9. westcoastblazin
    Oct 3, 2004
    15
    Three posts up buddy, hehehehe :haha:
