stripped U-bolt - torque values?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Apr 12, 2001.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    What do ya'll use for a torque value for U-bolts on a front 10-bolt? The shop manual says 150, but I stripped out a new (ProComp) U-bolt at 150. (The bolt was new, threads cleaned on both the bolt and nut with brake cleaner and allowed to dry.) I am purchasing another set today and don't want to strip these out!
    DJ
    78 K5
  2. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    My local spring shop told me 125 for either the bolts that came with my lift kit or the custom ones I ended up having them make for me. They also recommended that I use a "tall nut" (I do not know the correct name) which is just about two times as tall as the nuts that came with my lift kit (plus no nylock). They hold better according to the shop and are less likely to strip.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Don't take this as gospel, but I remember being told to "re-torque them to 100 lbs" a few years ago after I had front springs installed.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Mine are torqued to 100 also...
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  5. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    What shop manual were you using? My shop manual says 125 ft lbs. Are you sure you weren't looking at the Newton Meter (NM) number which the shop manual lists both.
    CB
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    When I did my lift last year I torqued them down to 125...thats what the Superlift paperwork said and its worked out just fine so far.
    '73 K5
    Chevy good...Ford bad
  7. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I used Superlift. I was having similar problems. They verified that the torque value is indeed 150 ft/lb. The torque value depends on the diameter of the bolt. It sould be able to take 150 ft/lbs. This is also what the factory specifies for stock set up. Try using anti-seize compound. This will prevent gawling of the threads and give you a better torque.
  8. djohnsn
    327
    Plano, Texas
    I am using 1978 and 1984 factory shop manuals. The 125 ft lbs is for the rear, with 150 ft lbs for the front.
    Wouldn't using antiseize distort the torque readings?
    DJ
    78 K5
  9. Storm Trooper
    Nov 24, 2000
    4,640
    My Chiltons $hit manual said 150lbs. but I only went to 100.
    I figured I would run it for a while, then retorque.
    I don't belive any of them because the rear U-bolts are larger than the front and should have different spec.s (don't you)
    dump the crap u-bolts you have, they should still take 125.
  10. lasvegas
    Feb 27, 2001
    122
    Las Vegas, Nevada
    using anti-sieze affects torque reading. Your shop manual should say something like "All torque values are dry unless otherwise specified". 150 pounds wet is not the same as 150 dry.
  11. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Hi Guys, Well I watched when using the "cheap" U bolts that the bolts them selfs will strecth. I'll never use them. I ALLWAYS use good U bolts, with the long nuts (more threads,) and put "antisieze" on the threads. I allways retourque them after a few miles. I never use a tourque wrench, just my BIG impact. If they are good bolts they will take it. GOPHERKILLER
  12. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    As an aircraft mechanic, when ever we use high torque values antisieze is a must due to the friction the higher torque values create. Antisieze is a must for a true torque value on high torque aplications as the friction creates resistance and the resistance affects torque. I've seldom seen it used in automotive applications except in high heat areas such as spark plugs and exhaust components. You also SHOULDN'T need it on new hardware. This is all according to aircraft technical manuals. -Tommy
  13. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Didn't they engineer that thought into the original torque value for the size bolt and torque amount????
  14. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    let me check my impact to see what the ft/lbs is.hehe!i run mine down till they quit turnin.never had a prob.
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
