Stripping interior
Discussion in 'The Garage' started by FL84K5, Sep 6, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Would it be ok to run with the interior stripped out and the top off without some type of bed liner for awhile? I want to strip the interior, and take the top and doors off for a run this fall but wont be able to get the interior lined till sometime after. What can I do to cut down the heat coming thourhg the floor that i can still hose off?
  2. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    bump
  3. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    Well it should be ok to run it like that if you are going to be lining it later just keep metal exposed spots covered with primer or paint .But If this is the first time that you have ever taken out the interior be prepared to be shocked. You will find rust holes and missing metal everywhere.. When I did my k5 it looked descent from underneath but when I stripped the interior thats when the true story unfolded..good luck
  4. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    Herculine it. I just did my cab and tailgate. As soon as I get the holes in the bed welded up I'll be herculining that too. Should be done by next weekend and I'll post pic's. Pretty easy on the pocket book too, about 85.00 for the kit.
  5. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    How hard is it to do it? I've never doneanything like it.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I hurculined my interior. took about 4 hrs. firewall to tailgate. I don't have a top, I just throw a cheap tarp over drivers area when not using and let the rain fall!! Runs out some drain holes I put in floor.
  7. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    i just stripped my front, and man, there's a lot of heat coming up! just great for these 90-100 degree LA days!
  8. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
    The Herculiner is a peice of cake. Scuff up the surface. Then clean the area. Then tape off the area you don't want coated then lay on one good coat. Wait about two hours then put on a second coat. Check out this site with video's.
    Herculiner
