Strong 5-speed manual adaptable to an np203?
Discussion in 'The Garage' started by BorregoK5, Oct 22, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    What are my options for this combo, personal opinions on strength of the tranny? Want the 203 compatability for a doubler setup. Any price vs performance compromises with similar setups or custom doublers off other t-case's?
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I suspect the NV4500 is about the only option out there.
    John
  3. Grim-Reaper
    7,385
    Atlanta
    Nv4500$$$$$ and Advanced Adaptors$$$$$ is about it. The NV was mated to a 241 I think but it's a driver side drop so not going to work. If you were putting this in a truck you might be able to run a divorced 205. Not really enough room to do that on a K5 though.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A pass-drop 241C from a TH400/4L80E will bolt straight up to a 4wd NV4500. I think the only think you'd find this 32-spline 241C in is a 88-91 3/4-ton.
    For NV4500/NP203 compatibility....
    The Ford NP203 has the same 6-bolt round pattern as the NV4500. If you swapped a 32-spline (TH400) input into the Ford 203, they *should* bolt up (possibly needing a thin spacer).
    Another route is to re-drill a 32-spline NP203 for the 6-bolt pattern. (I think Steve Watson has endorsed this method)
