Stronger than a D60!!
Discussion in 'The Garage' started by alf4444, Aug 12, 2005.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Think this would fit in my 78 K5 :D
  2. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    hell, it doesn't even fit on the screen
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Somebodys got to ask, so i'll bite. What is it?
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    so are you after a new type of rock crawing -- ROCK CRUSHING--- that thing must be from a cement mixer or something :eek1:
  5. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Kress Hauler Axle these are our small ones you should see the Cat 797 axles :bow:
  6. jboyes
    jboyes 1/2 ton status
    Jan 27, 2005
    142
    SE KS
    I think it could work :thinking:
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    It wont fit in it, but i bet it would fit under it.
  8. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You would have to convert to airbrakes.
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    You'd need a big block for each axle...
  10. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Convert it to D44 disk brakes and you'd probably save about 200Lbs...
    It would get a little narrower too.
    What's the R&P ratio on that thing? :dunno:
  11. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    ot , but does anyone know what happened to the guy with the beefy "Marmon-Herrington" axle?
  12. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I wish i had a pic from when I was at Caterpiller in Peoria Illinois. The axles on the back of the big dump trucks are crazy.
  13. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Yes They are :eek1: :bow:
  14. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Back when I worked at the truck transmission place, we had a huge Cat axle from some kind of haul truck.
    24 inch ring gear!
    The pinion looked about as big as a 5-gal can, and had to be hoisted into place. The housing looked to be bracketed for a 3-link suspension setup. Multi-disc wet brakes inboard of the planetary hubs. The whole assembly shipped out at almost 6000 lbs...
