Strongest brakes for 10 bolt
Discussion in 'The Garage' started by k14, Apr 17, 2007.
  1. k14
    k14 Registered Member
    Aug 30, 2006
    30
    So.Nv.
    I've got an 80's 10 bolt front diff in my '66 Burb. I had planned on swapping in a 14 bolt ff rear and upgrading the 10 bolt to 8 lug with the heavier brakes, but now i'm thinking of staying with my current setup because I really like my wheels. Does anyone know of an oversized brake kit for the 6 lug 10 bolt. All I could find is this http://www.ssbrakes.com/products/detail/2702/?make=Chevrolet&model=Blazer+%28Fullsize+4WD%29&year=1984 . Does anyone know if larger rotors and calipers are made for this application. Thanks!
  2. k14
    Aug 30, 2006
    30
    So.Nv.
    Anybody? I did a search and couldn't find anything. Maybe going the 8 lug route is my only option?
  3. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I really dont know much; but if you put a 14 ff rear 8 lug, and change the front backing plates and brakes, you would have 8 lug all around. then see if they make a plate that uses 8 lugs and converts to 6.
    Are you going after bigger brakes or bigger rear end? I converted my front to 8 lug and my rear to 14 bolt SF, and my brakes stop me and a stumpgrinder well.
    Hope this is some help ---Jeff
  4. k14
    Aug 30, 2006
    30
    So.Nv.
    Thanks. I really just want bigger brakes to help when I tow a boat. I don't do any hardcore wheelin other than some sand dunning and wanted to keep my 6 lug axles.
  5. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    I say swap to some discs in the back, and you'd prob be happy with it. :)
  6. 74poj
    74poj Registered Member
    Apr 12, 2005
    46
    Montana
    if you're going 14bff in the rear just do the disc conversion. i'm running standard size brakes on my 8 lug 10b up front with the conversion in the rear. stops on a dime with 34's
  7. jeff l
    Jun 13, 2006
    104
    New Orleans
    Or/also get tralior brakes, that might be cheaper
  8. solidaxlesub
    solidaxlesub 1/2 ton status
    Feb 21, 2005
    171
    tri-cities, wa
    you could use the 6 lug hubs for the 14 bolt and convert it to disks with 1/2 ton rotors. problem solved:D
