strongest front axle other than dana60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, Oct 5, 2000.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I want a Dana, but is there anything stronger than a 60? I would like a direct bolt up.
    10 out of 11 people prefer Jimmys over Blazers.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Some will argue that a Dana 70 is stronger, but I have only seen closed knuckle variety 70s used in Dodge trucks (no open knuckles). Closed knuckles are not as strong as open, and the stub shafts are not as strong as the open 60s. Stick a 60 in there, its a simple task, unlike trying to adapt some huge-a$$ Dana 70, or Rockwell 2 1/2 ton into your truck. Some break 60s, but usually at the stub shafts, which can be upgraded to 35 spline from Dynatrack, and if you start blowing hubs, use the drive plates like Titanic on his Sub, you know the ones in your previous post about the pre'80 Dana 60s with full time hubs. Those things will not break!!!
    ken
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    If you are looking for a dana 60 or 70 front drop me a line
    at sgrossman@coinet.com
    Brian
    TOO MUCH IS JUST BARELY ENOUGH!!!
  5. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    ya Kens right on -seen 70 front at last mud meet lock up (the enclosed ends) ring and pinion and housing tough but no disk brakes and the outter shafts same size as D60. Not worth it unless find it for free. See tons of 60 upgrade and steering brake parts in mags.
  6. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    A) There is no such thing as a "direct bolt up"!!!!!heheheh and B) DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 DANA 60 [​IMG]HAVE A NICE DAY!!!!
    http://dblazer.coloradok5.com
  7. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    I was talking to some guys at the truck pulls this summer and the ss4x4 guys told me that they run a Dana 60 with Dana 70 internals
    Have been stuck (once) as of 8/12/00
    "(2H) Where's all the mud?.(4H)...(4L)..(4H)... oh crap"
