Stub shaft seal
Discussion in 'The Garage' started by shaun, May 21, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Help me please. I ordered a steering gearbox repair kit from kragen and autozone. Both were the same part number both are wrong. They are both an 1/8th inch to big in diameter so They wont fit. So I called and had them cross reference the original seal (7832426) and thet keep coming up with the seal that is the wrong size. Is my gearbox wrong. Both stores looked it up for a 90 gmc jimmy (fullsize) w/ a 350 and both are wrong. What do I do. Maybe it is time for the cross over swap????
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    go for the cross over, youll never regret it /forums/images/graemlins/waytogo.gif 2wd gear box, new dropped pitman arm, new steering knuckle and center link and tie rods. sounds like alot but well worth it. /forums/images/graemlins/waytogo.gif
  3. shaun
    Apr 22, 2003
    745
    I have to do it for under 300 though. Preferably lower
  4. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    i think I spent about that muchon everything including making all the sreering arms from 1.5 inch cold rolled steel bar, heim joints ect,ect /forums/images/graemlins/waytogo.gifyou can do it
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    anybody else. Kinda stuck here. It is the seal where the steering shaft goes into the box not the sector shaft. Has anybody ever replaced this? Anybody have a part number for it? Thanks
  6. shaun
    Apr 22, 2003
    745
    I figured it out. Apparently a truck and a blazer have a different box. I asked for the kit for an 85 k10 it was it. So Im guessing the prvious owner swapped a gearbox from a trudck onto the jimmy. So if you didnt know (or am I the only one) A truck and a jimmy have 2 different gearboxes. But the funnything is that a 2wd and 4wd have the same repair kits. So does this mean you cant use a 2wd sector shaft from a truck on a blazer box since they are two different seal repair kits???
