Stubshaft out to pull balljionts? Need a quick answer!!!
Discussion in 'The Garage' started by Okiemuddog, May 17, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Hey guys, I am getting ready to help a buddy do his balljoints on a 10 bolt. Do you have to pull the stub shafts out of the axles to get to the balljoint nuts or can you work around them? Thanks is advance.
    Krennen /forums/images/graemlins/thumb.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When you are down that far into the axle you can just pull both the inner and outer shafts out together. They just slip out. This would be a perfect time to replace the ujoints in there if they need it. You will loose some gear oil, but you can just add that back afterward.
    I would just pull them so you don't have to fuss and work around them.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The axles must be out in order to remove the knuckles regardless of wheather you can remove the lower ball joint nut with them in or not.
