stuck bolt PLEASE HELP ASAP
Discussion in 'The Garage' started by little79k5, Sep 7, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    Well started my lift this morning. so far i've pretty much had to cut most of the bolts off b/c they are so rusted on there. anyway, the bolt that holds the shackle to the hanger in the rear, i couldnt get it loose so i cut the head off in hopes of punching it out. now i cant get the piece of crap out!! ive tried vise grips, a punch, a gear puller (to press it thru), etc. with no luck. what are my options?? thanks.
    keith
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    take the load off the springs and just use a hammer and punch and punch it through it will eventuily come out
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    When I put on my lift, I had the same sort of problem. Your situation may be more involved than you think. The bolt is rusted into the metal sleeve in the rubber bushing. Trying to punch it through will get you no where (not to mention it will give you a wonderful ringing in your head for a while)
    After hours with a 3lb mallet, I gave up and rented an acetylene torch. With this, I cut through the bolt on the inside of the shackle (which freed up the spring/shackle) and then melted the bolt out of it's hole in the shackle. The only downside to this method is that you will have to locate a new bushing for your shackle - but that downside is balanced out by the fact that you get to cut through metal with fire.
    If you end up torching, have a bucket of water and a soaked rag nearby because the rubber bushing will catch fire/smolder for a while.
    Good luck, and remember - the finished product will be well worth the effort.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    PB Blaster, and as mudhog said, make sure as uch load is off it as possible.
  5. little79k5
    Mar 27, 2002
    230
    panama city, fl
    yeah, i found out that it was stuck to the sleeve. i was able to cut the ends of the bolt off and pull the spring out and i used a gear puller to press out the sleeve and stuck bolt, so all i need is a sleeve and bolt.
    thanks
    keith
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your grinder and sawzall are your friend if you dont have a torch.
  7. little79k5
    Mar 27, 2002
    230
    panama city, fl
    yes they are!!! /forums/images/icons/grin.gif
