Stuck brake drums ?
Discussion in 'The Garage' started by 85k5dsl, Jan 15, 2007.
  1. 85k5dsl
    85k5dsl 1/2 ton status
    Feb 23, 2006
    253
    Maryland
    Well I picked up a truck a few months ago for the axles, drove in the yard and stripped it down. I went to start tearing the axle down , 14 BFF, and can not get the brakes to release. I have soaked the star adjust with PB Blaster and disengaged the level but can not get the adjust to move. I've now sc***ed myself because I could not leave it be and the adjuster is chewed up. What options do I have, I don't want to destroy the drums because a disc convertion is not in the budget at this time. Thank for any and all help.
    Mark
    :confused:
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Cut the pins that hold the shoes to the backing plate. You can get a chisle or something under em and hold the pin out, then you can cut it. I cut mine with a pair of linesman plyers.
  3. 85k5dsl
    Feb 23, 2006
    253
    Maryland
    Dustin,
    Thank I'll give it a try.
    Mark
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Did you try backing the bleeder out and wiggling the drum?
